Are there any 5G Combatable device that people have used in the local USB port in the MX Series?
https://documentation.meraki.com/MX/Cellular/3G//4G_Cellular_Failover_with_USB_Modems lists all compatible USB modems. 5G is not supported from my point of view.
Is the Current Modems section of the referenced documentation blank for everyone else?
I was hoping someone may of tried it and had a working one and that Meraki is just slow to update the guidance.
When asking questions like this you need to say which country you are in and which carrier you are using.
Carrier is not relevant as we can move carrier and we operate in multiple places in EU, UK, and USA for the record.
Some cards are only available from some carriers. Some cards are only approved for use in certain countries. Some carriers block non approved cards.
The easy option is to use the MG21 (although note there were two versions depending on where you are in the world).
The gateway connects via RJ45 whereas we are looking for a 5G option that connected directly to the USB on the Device. Not to worry. Thanks all.
