Secure Connect topology
Messy
Looking to use Secure connect for the cloud firewall and have a few design questions.
Currently we have about 60 sites around the world in a hub and spoke setup using meraki auto-VPN using MX devices.
The easiest setup seems to be to just connect every site to a secure connect hub, internet traffic goes to SC and internal routes through SD-WAN.
However, I read in Meraki docs that Secure connect adds latency that would impact sensitive traffic like Voip etc.
2. How do we define traffic that should go straight out to internet rather than use SC ?
Also, regarding existing hubs -when you join them they don't receive a default route from a Secure Connect hub by default.
Is this the recommended setup? Why is this the default? is there some significant downside toa  Hub site having its internet traffic go through secure connect?
What does this mean for their internet traffic? presumably the default behavior is that it goes out to internet directly as it did before? In which case what is the point in connecting it to Secure connect?
thanks!
ChristopherR
Once you've connected a site to Secure Connect, you can configure which traffic to go direct to the Internet under Security & SD-WAN > SD-WAN & Traffic Shaping >Local Internet Breakout. Here you can define VPN Exclusion rules for which traffic to bypass going down the tunnel. With the SDWAN+ license, there is also an option to exclude traffic at the application level for a handful of popular well known applications.
As to your note on the hubs joining Secure Connect not receiving a default route by default, I believe when this was originally designed it was to help prevent customers from unknowingly having all their traffic sent through Secure Connect. Let's say you had a default security policy for HTTPS inspection in Umbrella but didn't have the cert deployed to all the endpoints connected to the hub: this could lead to an unpleasant experience for users trying to access HTTPS pages without the cert loaded. This configuration is definitely supported and I'd recommend reaching out to the Secure Connect support team (just use any support link from a Secure Connect page in the dashboard). I thought it was just a matter of ensuring that the Secure Connect hub was listed as a higher priority under Security & SD-WAN > Site-to-site VPN at the site in question.
The value of having the Internet traffic going through Secure Connect would be for additional security functionality like HTTPS inspection, tenant controls, DLP functionality, sandboxing, web app controls, etc.
Using Secure Connect to configure your cloud firewall can be beneficial, but it does require some consideration.
I think it would be a good idea to consult a Meraki SE to help you define the best design for your environment.
Messy
yea that was my first port of call but they aren't very helpful. We have had several "introduction" meetings, you know "just to say hello"...every time i try to get an actual technical meeting with a technical person, best i can manage is a sales guy who thought the meeting was just an introduction and he will pass on questions to the engineers - only to never hear from anyone again.
ChristopherR
Messy
brill, thanks very much!
