Searching for a Hub or Spoke by WAN IP
rhbirkelund
Either I'm too blind to see the method, or I'm missing a method to find a Spoke Site.
I have a bunch of VPN connections going up and down, being logged in the Event Log. This event only logs the WAN IP of the site. However, I have no way of finding out what site this IP refers to.
With a handful of sites this is not real issue, but once we hit hundreds of sites, I have no idea this site the IP belongs to.
Is it possible that the event could include the MX Hostname, of the other end of the VPN? Or even a link to said site?
9 Replies 9
JamesT91
Organization > Overview > Devices (tab) > Use settings cog to add 'Public IP' column
I believe this should give you a view of what you want.
rhbirkelund
Aha! - Never too old to learn new tricks!
It's close though, but unfortunately no cigar. It looks like this particular IP isn't showing up in the list, so I'm guessing it's a WAN2 Public IP.
JamesT91
What about if you add instead the Uplink IP (Port 1) and (Port 2) columns?
rhbirkelund
Same, IP doesn't show up, unfortunately.
JamesT91
That's strange, I've just looked at a few different Orgs and for MX devices those 2 columns are all displaying the devices correct WAN 1 and WAN 2 IP.
rhbirkelund
Are the IPs directly on the WAN interfaces? I suspect, it's only showing the Uplink IP, which may be NAT'ed
JamesT91
Ah that will be the difference then. 99% of our deployments will have the public IP directly on the interface.
RaphaelL
Best way to do it is with the API.
Dashboard is unrealiable as you saw. I had a case opened years ago about WAN2 not showing up from Organization > Overview > Devices , the response was : it's working as designed.
rhbirkelund
Yeah, I was considering just making a search tool to lookup the appliance with the matching IP.
