Searching for a Hub or Spoke by WAN IP
rhbirkelund
Either I'm too blind to see the method, or I'm missing a method to find a Spoke Site.
I have a bunch of VPN connections going up and down, being logged in the Event Log. This event only logs the WAN IP of the site. However, I have no way of finding out what site this IP refers to.
With a handful of sites this is not real issue, but once we hit hundreds of sites, I have no idea this site the IP belongs to.
Is it possible that the event could include the MX Hostname, of the other end of the VPN? Or even a link to said site?
7 Replies 7
jimmyt234
Organization > Overview > Devices (tab) > Use settings cog to add 'Public IP' column
I believe this should give you a view of what you want.
rhbirkelund
Aha! - Never too old to learn new tricks!
It's close though, but unfortunately no cigar. It looks like this particular IP isn't showing up in the list, so I'm guessing it's a WAN2 Public IP.
jimmyt234
What about if you add instead the Uplink IP (Port 1) and (Port 2) columns?
rhbirkelund
Same, IP doesn't show up, unfortunately.
jimmyt234
That's strange, I've just looked at a few different Orgs and for MX devices those 2 columns are all displaying the devices correct WAN 1 and WAN 2 IP.
rhbirkelund
Are the IPs directly on the WAN interfaces? I suspect, it's only showing the Uplink IP, which may be NAT'ed
jimmyt234
Ah that will be the difference then. 99% of our deployments will have the public IP directly on the interface.
