On Ramp for public Cloud?
N0body
hi Guys
Whats the best way to connect to IaaS resources on Azure or AWS?
Is there an OnRamp functionality where I dont have to deploy vMX's on the Azure/AWS side?
Could you point me to some documentation?
Many thanks!
GreenMan
Meraki Employee All-Star
I'd go for this instead:
https://documentation.meraki.com/MX/Deployment_Guides/vMX_and_Azure_Route_Server
A lot will depend on how important the service is to you - a single IPsec tunnel to a single IPSec terminator is pretty simple on a drawing - less easy to set up as it's cross-vendor.   And if any point of it fails, you might be wishing you'd invested a bit more time in a resilient solution up-front...?
7 Replies 7
GreenMan
What's the objection to deploying vMX?   It really is the best way to do this, if you're an MX SD-WAN user.
N0body
no objection 🙂  , I am looking for the Cisco recommended way of doing it.
Using a pair vMX's would mean 2 additional appliances i'd need to pay for/manage. Using an OnRamp type functionality (if it exists) might connect me via a VPN Gateway. i was interested to see if there was an OnRamp and how it would work.
GreenMan
Nope - vMX is what you need!
Gary_Geihsler1
Meraki Alumni (Retired)
Depending on the public cloud platform you could use an IPsec tunnel. We can use the native IPsec capabilities of Azure and GCP, probably others I have not tested OCI for instance. AWS is the outlier, we can not do IPsec to the AWS native site to site infrastructure. In AWS you would need either a virtual router/firewall of your choice and use IPsec or use a vMX(preferred) to make the connection to Cisco+ Secure Connect.
GreenMan
No question that @Gary_Geihsler1 's solution would work, but you did ask for 'the best way' and I suspect he'd agree with me that vMX (with simpler setup, failover & loadbalancing, policy and performance based routing etc) is much better than a non-Meraki VPN tunnel to ANOther IPSec terminator running in your cloud platform.
N0body
Yep , im looking for the best way!
If i have 2 x vMX deployed on Azure , i'd need to set up failover using Azure functions
https://documentation.meraki.com/MX/Other_Topics/Deploying_Highly_Available_vMX_in_Azure
creating an ipsec tunnel between secure connect and an Azure VPN gateway looks like the less complicated option. On the Azure side , routes would point to the VPN gateway and i wouldnt have to mess around with functions.
Policy/performance based routing outbound from Azure isnt too important to me.
thanks for your input so far , this is all very useful!
GreenMan
