Hi, we are in the early stages of implementing Cisco Secure Connect. Completed the Azure AD/Entra ID SAML integration, followed instructions for the SSO with SAML and it is working but not quite as I expected. We use the Cisco Secure Client app, after connecting there is a Azure AD Login Window and then you can enter your user name and password. However, I expected a SSO experience similar to other SAML/SSO integrated apps in which Entra ID automatically authenticates the user or allows you to select the user account to use for authentication. Am I not configuring the Entra ID Enterprise app correctly or is it just not possible for a seamless SSO experience similar to what we had when using a Cisco ASA for VPN?
