Would it be possible and if so, would there be any limitations or security issues, to use Netgear's Nighthawk M6 Pro on my Meraki GO systems.
Hello @dcrom
You can use different devices with Meraki GO. There shouldn't be security issues with that.
You can find more information here: Meraki Go - Recommended Meraki Go Topology - Cisco Meraki
To offer better help, you would need to specify what Meraki GO devices you want to use with the Nighthawk.
Cheers
Thanks for the reply. I have a Meraki GO 24 port POE Switch, a Meraki GO 5 port gateway and Meraki GO indoor and outdoor WIFI access points
Appreciate any suggestions.
We have Spectrum for internet which enables our phone system, (Ring Central). For the past several weeks they have working on an issue locally and our calls will drop, we cannot process payments, etc. I was trying to find a solution in the form of a secondary internet connection. I have looked into Starlink and Netgear Nighthawk M6 Pro.
It isn't easy to make any suggestions without knowing more.
I assume:
- You are using the Meraki GO gateway (GX-20 or GX-50) with a static WAN-IP on your Spectrum modem. If not it might be worth to give that type of connection a try.
- Phones are connected directly to the Spectrum modem and are not part of the Meraki GO network.
I assume that, because I have a similar setup at home with my cable ISP.
I don't see how a secondary internet connection (Starlink or Nighthawk) will fit in that type of setup, since the Meraki GO gateway offers only one WAN-port. You would have to switch the connection manually and you might have to change settings on the gateway every time you do that. Not knowing which connection is stable or not at the given time.
When you say they are working on an issue locally, this issue happens at your place or in your area? Did you ask Spectrum to replace the modem?
Thanks again for your reply.
Some ISPs offer a failover-solution and some don't. My cable ISP at home doesn't offer this option, while my ISP at my workplace offers this solution. It comes with another plan. My business doesn't depend on an internet connection like yours.
My suggestion would be, to look for an ISP, who offers a plan that includes a failover-solution. Usualy it comes with a smaller price then having two plans from different ISPs.
If that's not available look for a dual-WAN or multi-WAN router. Some have a build in 5G modem and some will need a dedicated modem for it.
Spectrum business does offer a failover solution. It is $99.00 set-up fee/ $20.00 per month per location. I would not have known but for your suggestion.
Thanks!
