Remote Deployment?
Remote Deployment?
Is it possible to remotely deploy Meraki Go APs if you have the serial numbers?
Say for example I have a business client that is out of state. Can I ship the APs to them and yet use the app remotely to configure them? Or do you have to physically scan the QR code?
Accepted Solutions
Meraki Go Team
Re: Remote Deployment?
Hey Scott!
The Meraki Go app does allow you to enter the serial number instead of scanning the QR code on the device.
You do still have the ability to configure the AP within the app prior to giving it Internet connectivity for it to check-in successfully.
Cheers,
Dom Wilkins
1 REPLY 1
Meraki Go Team
Hey Scott!
Cheers,
Dom Wilkins
