Merging Meraki Go APs with "regular" Meraki APs?
Tyler_Durden
I just read about Merkai Go.
I wonder if I can merge the Mearki Go AccessPoints with the regular Meraki AccessPoints, for example MR33?
Or, in other words, can I claim, configure and monitor the Meraki Go Access Points in the well-known Meraki dashboard, along with regular Meraki devices?
Thanks in advance
shannonh
Meraki Alumni (Retired)
Hi @Tyler_Durden!
Welcome to the Meraki Go Community!
Meraki Go access points can only be managed via the Go mobile app and cannot be managed via the Enterprise Meraki dashboard. Also, you can't manage Enterprise access points or use the Enterprise dashboard credentials on the Meraki Go app.
Cheers!
- Shannon
3 REPLIES 3
shannonh
Hi @Tyler_Durden!
Cheers!
- Shannon
Hi @shannonh
Thank you so much for you reply!
Now it´s clear to me.
Have a nice day
Cheers
Michael
Meraki Go is a different umbrella within Meraki, I won't expect compatibility with the Enterprise line of products.
