Meraki Go Switch GS110-24p poe Firmware Not running configured version
TechlabItalia
Hi everyone, I have a problem on a GS110-24P poe switch device. A few days ago it started having network problems on all ports. No traffic passes through anymore but it only manages to power the GR10 access points. Checking on the cloud shows a firmware error. What can it be?
1 Reply 1
TyShawn
I had this issue on a Meraki propper switch. I ended up rebooting my switch which resolved the issue. Some things to try is verify your switches IP, subnet mask, gateway, and DNS servers if you have custom settings. Also, try a reboot, and lastly a factory reset.
