Quick question. Can I run the GX20 with PoE or do I always need a power cord/power adapter?
You can not run the GX20 on PoE.
Meraki Go Router Firewall / Router Firewall Plus Switch Ports - Cisco Meraki
I have a GX20 and it NEEDS the power adapter. The APs like the GR10 can run on PoE though.
@Max123 Correct, you always need an external power adapter for GX20/GX50.
NO Meraki Go Security Appliance or Switch can be fed with electricity by PoE.
Only Access Points can.
\\n\\t\\t\\t\\t\\t\\tSorry, unable to complete the action you requested.\\n\\t\\t\\t\\t\\t<\\/p>\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\n\\t\\t\\t\\t\\n\\t\\t\\t<\\/div>\\n\\n\\t\\t\\t\\n\\t\\t<\\/div>\";LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_2c7cecd32ee54f', 'disableAutoComplete', '#ajaxfeedback_2c7cecd2f7e0c5_0', 'LITHIUM:ajaxError', {}, 'WyoauSPU8jVxPqmXqWDQ-lUwvUqx8pwAyMDOIZT_9Ps.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":3},"inputSelector":"#messageSearchField_2c7cecd2f7e0c5_0","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.messagesearchfield.messagesearchfield:autocomplete?t:ac=board-id/forum/message-id/1654&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_2c7cecd3a00d51', 'disableAutoComplete', '#ajaxfeedback_2c7cecd2f7e0c5_0', 'LITHIUM:ajaxError', {}, 'dcJ9QrdDK-OudW1CnP1b7jHbwNVOwhuiTIEVQgiyhmU.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":3},"inputSelector":"#messageSearchField_2c7cecd2f7e0c5_1","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.tkbmessagesearchfield.messagesearchfield:autocomplete?t:ac=board-id/forum/message-id/1654&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.Placeholder(); LITHIUM.AutoComplete({"options":{"triggerTextLength":0,"updateInputOnSelect":true,"loadingText":"Searching for users...","emptyText":"No Matches","successText":"Users found:","defaultText":"Enter a user name or rank","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_2c7cecd3cb409a', 'disableAutoComplete', '#ajaxfeedback_2c7cecd2f7e0c5_0', 'LITHIUM:ajaxError', {}, 'kDLCEG2KdHcFlQXj2irZfIVYdWGNlWoBjXDhFNOjbB0.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#userSearchField_2c7cecd2f7e0c5","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.usersearchfield.usersearchfield:autocomplete?t:ac=board-id/forum/message-id/1654&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:userExistsQuery","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":"#userSearchField_2c7cecd2f7e0c5","action":"userExistsQuery","feedbackSelector":"#ajaxfeedback_2c7cecd2f7e0c5_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.usersearchfield:userexistsquery?t:ac=board-id/forum/message-id/1654&t:cp=search/contributions/page","ajaxErrorEventName":"LITHIUM:ajaxError","token":"Parw6iX9LVxLlBie6kF49vr_r6X6fW9LlFc-usM69ys."}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_2c7cecd3f5c3f1', 'disableAutoComplete', '#ajaxfeedback_2c7cecd2f7e0c5_0', 'LITHIUM:ajaxError', {}, 'lj1f78SPpQf4GpGYNU0G5Ez3zc1lLAI-8rvaIyiCU6s.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#noteSearchField_2c7cecd2f7e0c5_0","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.notesearchfield.notesearchfield:autocomplete?t:ac=board-id/forum/message-id/1654&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.AutoComplete({"options":{"triggerTextLength":4,"updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('',{method:'POST',action:$link.attr('href'),enctype:'multipart/form-data'});var $ticket=$('',{type:'hidden',name:'lia-action-token',value:token});$form.append($ticket);$(document.body).append($form);$form.submit();$doc.trigger('click');}}}\nif($doc.data('lia-link-action-handler')===undefined){$doc.data('lia-link-action-handler',true);$doc.on('click.link-action',params.linkSelector,handler);$.fn.on=$.wrap($.fn.on,function(proceed){var ret=proceed.apply(this,$.makeArray(arguments).slice(1));if(this.is(document)){$doc.off('click.link-action',params.linkSelector,handler);proceed.call(this,'click.link-action',params.linkSelector,handler);}\nreturn ret;});}}})(LITHIUM.jQuery);\r\n\nLITHIUM.Link({\n \"linkSelector\" : \"a.lia-link-ticket-post-action\"\n});LITHIUM.AjaxSupport.fromLink('#disableAutoComplete_2c7cecd41cc26f', 'disableAutoComplete', '#ajaxfeedback_2c7cecd2f7e0c5_0', 'LITHIUM:ajaxError', {}, 'oX9kt1VhX19mzKMDMqNJc5UCVobakvqJcKOhbqvjl2Y.', 'ajax');","content":"Turn off suggestions<\/a>"}],"prefixTriggerTextLength":0},"inputSelector":"#productSearchField_2c7cecd2f7e0c5","redirectToItemLink":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.searchformv32.productsearchfield.productsearchfield:autocomplete?t:ac=board-id/forum/message-id/1654&t:cp=search/contributions/page","resizeImageEvent":"LITHIUM:renderImages"}); LITHIUM.Link({"linkSelector":"a.lia-link-ticket-post-action"}); LITHIUM.AjaxSupport.fromLink('#enableAutoComplete_2c7cecd2f7e0c5', 'enableAutoComplete', '#ajaxfeedback_2c7cecd2f7e0c5_0', 'LITHIUM:ajaxError', {}, '-s7AC0jaXxWXnUbl-os25GzJaZItLJA-ovEnFvnOoWw.', 'ajax'); LITHIUM.Tooltip({"bodySelector":"body#lia-body","delay":30,"enableOnClickForTrigger":false,"predelay":10,"triggerSelector":"#link_2c7cecd2f7e0c5","tooltipContentSelector":"#link_2c7cecd2f7e0c5_0-tooltip-element .content","position":["bottom","left"],"tooltipElementSelector":"#link_2c7cecd2f7e0c5_0-tooltip-element","events":{"def":"focus mouseover keydown,blur mouseout keydown"},"hideOnLeave":true}); LITHIUM.HelpIcon({"selectors":{"helpIconSelector":".help-icon .lia-img-icon-help"}}); LITHIUM.SearchAutoCompleteToggle({"containerSelector":"#searchautocompletetoggle_2c7cecd2f7e0c5","enableAutoCompleteSelector":".search-autocomplete-toggle-link","enableAutocompleteSuccessEvent":"LITHIUM:ajaxSuccess:enableAutoComplete","disableAutoCompleteSelector":".lia-autocomplete-toggle-off","disableAutocompleteSuccessEvent":"LITHIUM:ajaxSuccess:disableAutoComplete","autoCompleteSelector":".lia-autocomplete-input"}); LITHIUM.SearchForm({"asSearchActionIdSelector":".lia-as-search-action-id","useAutoComplete":true,"selectSelector":".lia-search-form-granularity","useClearSearchButton":false,"buttonSelector":".lia-button-searchForm-action","asSearchActionIdParamName":"as-search-action-id","formSelector":"#lia-searchformV32_2c7cecd2f7e0c5","nodesModel":{"tkb|tkb":{"title":"Knowledge base","inputSelector":".lia-search-input-tkb-article"},"forum|forum-board":{"title":"Search Board: Questions (and Answers!)","inputSelector":".lia-search-input-message"},"go|category":{"title":"Search Community: Questions (and Answers!)","inputSelector":".lia-search-input-message"},"user|user":{"title":"Users","inputSelector":".lia-search-input-user"}},"asSearchActionIdHeaderKey":"X-LI-AS-Search-Action-Id","inputSelector":"#messageSearchField_2c7cecd2f7e0c5_0:not(.lia-js-hidden)","clearSearchButtonSelector":null}); // LITHIUM.DropDownMenu({"userMessagesFeedOptionsClass":"div.user-messages-feed-options-menu a.lia-js-menu-opener","menuOffsetContainer":".lia-menu-offset-container","hoverLeaveEvent":"LITHIUM:hoverLeave","mouseoverElementSelector":".lia-js-mouseover-menu","userMessagesFeedOptionsAriaLabel":"Show contributions of the user, selected option is Options. You may choose another option from the dropdown menu.","disabledLink":"lia-link-disabled","menuOpenCssClass":"dropdownHover","menuElementSelector":".lia-menu-navigation-wrapper","dialogSelector":".lia-panel-dialog-trigger","messageOptions":"lia-component-message-view-widget-action-menu","menuBarComponent":"lia-component-menu-bar","closeMenuEvent":"LITHIUM:closeMenu","menuOpenedEvent":"LITHIUM:menuOpened","pageOptions":"lia-component-community-widget-page-options","clickElementSelector":".lia-js-click-menu","menuItemsSelector":".lia-menu-dropdown-items","menuClosedEvent":"LITHIUM:menuClosed"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#pageInformation","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_0","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_1","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenu({"userMessagesFeedOptionsClass":"div.user-messages-feed-options-menu a.lia-js-menu-opener","menuOffsetContainer":".lia-menu-offset-container","hoverLeaveEvent":"LITHIUM:hoverLeave","mouseoverElementSelector":".lia-js-mouseover-menu","userMessagesFeedOptionsAriaLabel":"Show contributions of the user, selected option is Show Meraki GX20 ran by PoE? post option menu. You may choose another option from the dropdown menu.","disabledLink":"lia-link-disabled","menuOpenCssClass":"dropdownHover","menuElementSelector":".lia-menu-navigation-wrapper","dialogSelector":".lia-panel-dialog-trigger","messageOptions":"lia-component-message-view-widget-action-menu","menuBarComponent":"lia-component-menu-bar","closeMenuEvent":"LITHIUM:closeMenu","menuOpenedEvent":"LITHIUM:menuOpened","pageOptions":"lia-component-community-widget-page-options","clickElementSelector":".lia-js-click-menu","menuItemsSelector":".lia-menu-dropdown-items","menuClosedEvent":"LITHIUM:menuClosed"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_0","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity', 'kudoEntity', '#ajaxfeedback', 'LITHIUM:ajaxError', {}, 'voAgdtix4knPiD8dIG7A7pM7zcdrqVTKI-bZLHW-lek.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "190037", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","renderEventParams":{"replyWrapperId":"replyWrapper","messageId":190037,"messageActionsId":"messageActions"},"isRootMessage":true,"collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions","loaderSelector":"#loader","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer","loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false,"linearDisplayViewSelector":".lia-linear-display-message-view","threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","isLazyLoadEnabled":false,"layoutView":"threaded","isAllowAnonUserToReply":true,"replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/forum/message-id/1654&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"uHILZRe2y7nUpvF9_YOLk_6FiT0YzLph0RPpo6cERFE."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/forum/message-id/1654&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"efImxPfXlbVlAAAYcHVgMdyZJ3qmM5kJSRfRMPog9Ow."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "190037", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1101110111111111111110111110100101111101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_2","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenu({"userMessagesFeedOptionsClass":"div.user-messages-feed-options-menu a.lia-js-menu-opener","menuOffsetContainer":".lia-menu-offset-container","hoverLeaveEvent":"LITHIUM:hoverLeave","mouseoverElementSelector":".lia-js-mouseover-menu","userMessagesFeedOptionsAriaLabel":"Show contributions of the user, selected option is Show comment option menu. You may choose another option from the dropdown menu.","disabledLink":"lia-link-disabled","menuOpenCssClass":"dropdownHover","menuElementSelector":".lia-menu-navigation-wrapper","dialogSelector":".lia-panel-dialog-trigger","messageOptions":"lia-component-message-view-widget-action-menu","menuBarComponent":"lia-component-menu-bar","closeMenuEvent":"LITHIUM:closeMenu","menuOpenedEvent":"LITHIUM:menuOpened","pageOptions":"lia-component-community-widget-page-options","clickElementSelector":".lia-js-click-menu","menuItemsSelector":".lia-menu-dropdown-items","menuClosedEvent":"LITHIUM:menuClosed"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_1","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_0', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_0', 'kudoEntity', '#ajaxfeedback_0', 'LITHIUM:ajaxError', {}, 'Q6u_CJY0cwKqTWZ24sDFNtF-a5HqFV_PNPEW42b44Ck.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_0", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "190045", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","renderEventParams":{"replyWrapperId":"replyWrapper_0","messageId":190045,"messageActionsId":"messageActions_0"},"isRootMessage":false,"collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_0","loaderSelector":"#loader","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_0","loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false,"linearDisplayViewSelector":".lia-linear-display-message-view","threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","isLazyLoadEnabled":false,"layoutView":"threaded","isAllowAnonUserToReply":true,"replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_0","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/forum/message-id/1654&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"qjOUvlBbCPa_2p3ZYa94fflBdD7l5seLW5-DYciyadw."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_0","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/forum/message-id/1654&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"FJL6QCiMakQhDEfZpHjjRKv9LmHSUYNJ-sf1Pfcfe5o."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_0", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "190045", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110111111111111110111110100101011101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper","componentSelector":"#threadeddetaildisplaymessageviewwrapper","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":190045,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/forum/message-id/1654","ajaxErrorEventName":"LITHIUM:ajaxError","token":"L4J6jgWLDgqOhmwBwMOrUriVuHS3vaZMojVB2Xv5IOs."}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_8","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_2","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_1', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_1', 'kudoEntity', '#ajaxfeedback_1', 'LITHIUM:ajaxError', {}, 'P4w420YIbchUlBVIUQRrnhk3jDMUM1SLU2mBEw2pLnM.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_1", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "193877", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","renderEventParams":{"replyWrapperId":"replyWrapper_1","messageId":193877,"messageActionsId":"messageActions_1"},"isRootMessage":false,"collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_1","loaderSelector":"#loader","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_1","loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false,"linearDisplayViewSelector":".lia-linear-display-message-view","threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","isLazyLoadEnabled":false,"layoutView":"threaded","isAllowAnonUserToReply":true,"replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_1","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_1","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/forum/message-id/1654&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"zBVnov54shlmeQ_eL1CJrDMcfr5BNOES-qbx2BN_nnk."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_1","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_1","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/forum/message-id/1654&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"_G9Vh61RdhgGqdwdR3YybEyPmAov4qUro-qiq1f0zu8."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_1", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "193877", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110111111111111110111110100101011101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper_0","componentSelector":"#threadeddetaildisplaymessageviewwrapper_0","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":193877,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper_0 .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper_0","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/forum/message-id/1654","ajaxErrorEventName":"LITHIUM:ajaxError","token":"1gV2B5BLSao7NQF2lHNEKZgTsAlKD52f_jKauEUdjbE."}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_9","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_10","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_11","feedbackSelector":".InfoMessage"}); LITHIUM.DropDownMenuVisibilityHandler({"selectors":{"menuSelector":"#actionMenuDropDown_3","menuItemsSelector":".lia-menu-dropdown-items"}}); LITHIUM.MessageBodyDisplay('#bodyDisplay_2', '.lia-truncated-body-container', '#viewMoreLink', '.lia-full-body-container' ); LITHIUM.AjaxSupport.fromLink('#kudoEntity_2', 'kudoEntity', '#ajaxfeedback_2', 'LITHIUM:ajaxError', {}, 'HGOOLP1uEiY15bJNjMnanSbhOtxDnU-t8rEMBIsvN9k.', 'ajax'); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "kudoEntity", "actions" : [ { "context" : "envParam:entity", "action" : "rerender" } ] } ], "componentId" : "kudos.widget.button", "initiatorBinding" : true, "selector" : "#kudosButtonV2_2", "parameters" : { "displayStyle" : "horizontal", "disallowZeroCount" : "false", "revokeMode" : "true", "kudosable" : "true", "showCountOnly" : "false", "disableKudosForAnonUser" : "false", "useCountToKudo" : "false", "entity" : "193898", "linkDisabled" : "false" }, "initiatorDataMatcher" : "data-lia-kudos-id" }); LITHIUM.InlineMessageReplyContainer({"openEditsSelector":".lia-inline-message-edit","renderEventParams":{"replyWrapperId":"replyWrapper_2","messageId":193898,"messageActionsId":"messageActions_2"},"isRootMessage":false,"collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","messageActionsSelector":"#messageActions_2","loaderSelector":"#loader","topicMessageSelector":".lia-forum-topic-message-gte-5","containerSelector":"#inlineMessageReplyContainer_2","loaderEnabled":false,"useSimpleEditor":false,"isReplyButtonDisabled":false,"linearDisplayViewSelector":".lia-linear-display-message-view","threadedDetailDisplayViewSelector":".lia-threaded-detail-display-message-view","replyEditorPlaceholderWrapperSelector":".lia-placeholder-wrapper","renderEvent":"LITHIUM:renderInlineMessageReply","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","isLazyLoadEnabled":false,"layoutView":"threaded","isAllowAnonUserToReply":true,"replyButtonSelector":".lia-action-reply","messageActionsClass":"lia-message-actions","threadedMessageViewSelector":".lia-threaded-display-message-view-wrapper","lazyLoadScriptsEvent":"LITHIUM:lazyLoadScripts","isGteForumV5":true}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineMessageReply"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_2","action":"renderInlineMessageReply","feedbackSelector":"#inlineMessageReplyContainer_2","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:renderinlinemessagereply?t:ac=board-id/forum/message-id/1654&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"eSUocX-4Pvo-ASdAKdF7_zrKPVa3wyobRVAXy_SNQ5Y."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadScripts"},"tokenId":"ajax","elementSelector":"#inlineMessageReplyContainer_2","action":"lazyLoadScripts","feedbackSelector":"#inlineMessageReplyContainer_2","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.inlinemessagereplycontainer:lazyloadscripts?t:ac=board-id/forum/message-id/1654&t:cp=messages/contributions/messageeditorscontributionpage","ajaxErrorEventName":"LITHIUM:ajaxError","token":"siJKOG-Vh0XljB5CMY-ey22q70nGqpbJZpBvvzj2w3c."}); LITHIUM.AjaxSupport.ComponentEvents.set({ "eventActions" : [ { "event" : "approveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "unapproveMessage", "actions" : [ { "context" : "", "action" : "rerender" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "deleteMessage", "actions" : [ { "context" : "lia-deleted-state", "action" : "addClassName" }, { "context" : "", "action" : "pulsate" } ] }, { "event" : "QuickReply", "actions" : [ { "context" : "envParam:feedbackData", "action" : "rerender" } ] }, { "event" : "expandMessage", "actions" : [ { "context" : "envParam:quiltName,expandedQuiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswer", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "ProductAnswerComment", "actions" : [ { "context" : "envParam:selectedMessage", "action" : "rerender" } ] }, { "event" : "editProductMessage", "actions" : [ { "context" : "envParam:quiltName,message", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAction", "actions" : [ { "context" : "envParam:quiltName,message,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "ProductMessageEdit", "actions" : [ { "context" : "envParam:quiltName", "action" : "rerender" } ] }, { "event" : "MessagesWidgetMessageEdit", "actions" : [ { "context" : "envParam:quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "AcceptSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "RevokeSolutionAction", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeThreadUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "addMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "removeMessageUserEmailSubscription", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "markAsSpamWithoutRedirect", "actions" : [ { "context" : "", "action" : "rerender" } ] }, { "event" : "MessagesWidgetAnswerForm", "actions" : [ { "context" : "envParam:messageUid,page,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditAnswerForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] }, { "event" : "MessagesWidgetEditCommentForm", "actions" : [ { "context" : "envParam:messageUid,quiltName,product,contextId,contextUrl", "action" : "rerender" } ] } ], "componentId" : "forums.widget.message-view", "initiatorBinding" : true, "selector" : "#messageview_2", "parameters" : { "disableLabelLinks" : "false", "truncateBodyRetainsHtml" : "false", "forceSearchRequestParameterForBlurbBuilder" : "false", "kudosLinksDisabled" : "false", "useSubjectIcons" : "true", "quiltName" : "ForumMessage", "truncateBody" : "true", "message" : "193898", "includeRepliesModerationState" : "true", "useSimpleView" : "false", "useTruncatedSubject" : "true", "disableLinks" : "false", "messageViewOptions" : "1111110111111111111110111110100101011101", "displaySubject" : "true" }, "initiatorDataMatcher" : "data-lia-message-uid" }); LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"threadeddetaildisplaymessageviewwrapper_1","componentSelector":"#threadeddetaildisplaymessageviewwrapper_1","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":193898,"confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","loaderSelector":"#threadeddetaildisplaymessageviewwrapper_1 .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#threadeddetaildisplaymessageviewwrapper_1","action":"renderInlineEditForm","feedbackSelector":"#threadeddetaildisplaymessageviewwrapper_1","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist.threadeddetaildisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/forum/message-id/1654","ajaxErrorEventName":"LITHIUM:ajaxError","token":"t8BFe8LKdJnUQZKLzN7Jv_zlVgakNFfnGhAz47ACLrw."}); LITHIUM.ThreadedDetailMessageList({"renderLoadMoreEvent":"LITHIUM:renderLoadMoreMessages","loadingText":"Loading...","placeholderClass":"lia-messages-threadedDetailList-placeholder","loadFetchSelector":"#threadeddetailmessagelist .lia-load-fetch","rootMessageId":190037,"loadPageNumber":1}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderLoadMoreMessages","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":"#threadeddetailmessagelist .lia-load-fetch","action":"renderLoadMoreMessages","feedbackSelector":"#ajaxFeedback","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.threadeddetailmessagelist:renderloadmoremessages?t:ac=board-id/forum/message-id/1654","ajaxErrorEventName":"LITHIUM:ajaxError","token":"k2_MUFxcEpo29g1qCtJcLv6foVlAKynqGv-g-oQS_z0."}); LITHIUM.InlineMessageReplyEditor({"openEditsSelector":".lia-inline-message-edit","ajaxFeebackSelector":"#inlinemessagereplyeditor_0 .lia-inline-ajax-feedback","collapseEvent":"LITHIUM:collapseInlineMessageEditor","confimationText":"You have other message editors open and your data inside of them might be lost. Are you sure you want to proceed?","topicMessageSelector":".lia-forum-topic-message-gte-5","focusEditor":false,"hidePlaceholderShowFormEvent":"LITHIUM:hidePlaceholderShowForm","formWrapperSelector":"#inlinemessagereplyeditor_0 .lia-form-wrapper","reRenderInlineEditorEvent":"LITHIUM:reRenderInlineEditor","ajaxBeforeSendEvent":"LITHIUM:ajaxBeforeSend:InlineMessageReply","element":"input","clientIdSelector":"#inlinemessagereplyeditor_0","loadAutosaveAction":false,"newPostPlaceholderSelector":".lia-new-post-placeholder","placeholderWrapperSelector":"#inlinemessagereplyeditor_0 .lia-placeholder-wrapper","messageId":190037,"formSelector":"#inlinemessagereplyeditor_0","expandedClass":"lia-inline-message-reply-form-expanded","expandedRepliesSelector":".lia-inline-message-reply-form-expanded","newPostPlaceholderClass":"lia-new-post-placeholder","isLazyLoadEnabled":false,"editorLoadedEvent":"LITHIUM:editorLoaded","replyEditorPlaceholderWrapperCssClass":"lia-placeholder-wrapper","messageActionsClass":"lia-message-actions","cancelButtonSelector":"#inlinemessagereplyeditor_0 .lia-button-Cancel-action","isGteForumV5":true,"messageViewWrapperSelector":".lia-threaded-detail-display-message-view","disabledReplyClass":"lia-inline-message-reply-disabled-reply"}); LITHIUM.Text.set({"ajax.reRenderInlineEditor.loader.feedback.title":"Loading..."}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"useLoader":true,"blockUI":"","event":"LITHIUM:reRenderInlineEditor","parameters":{"clientId":"inlinemessagereplyeditor_0"}},"tokenId":"ajax","elementSelector":"#inlinemessagereplyeditor_0","action":"reRenderInlineEditor","feedbackSelector":"#inlinemessagereplyeditor_0","url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.inlinemessagereplyeditor_0:rerenderinlineeditor?t:ac=board-id/forum/message-id/1654","ajaxErrorEventName":"LITHIUM:ajaxError","token":"aE1ztBKbpE447awQwbT1LbbsXD4UzVyF88olrnLh2es."}); LITHIUM.InlineMessageEditor({"ajaxFeebackSelector":"#inlinemessagereplyeditor_0 .lia-inline-ajax-feedback","submitButtonSelector":"#inlinemessagereplyeditor_0 .lia-button-Submit-action"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lazyLoadComponent","parameters":{"componentId":"messages.widget.emoticons-lazy-load-runner"}},"tokenId":"ajax","elementSelector":"#inlinemessagereplyeditor_0","action":"lazyLoadComponent","feedbackSelector":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.threadeddetaildisplay.inlinemessagereplyeditor_0:lazyloadcomponent?t:ac=board-id/forum/message-id/1654","ajaxErrorEventName":"LITHIUM:ajaxError","token":"JCa3KtRDG_DvC99ENcO6pPwXV3xK_pOSiCaMFj8OLGw."}); LITHIUM.lazyLoadComponent({"selectors":{"elementSelector":"#inlinemessagereplyeditor_0"},"events":{"lazyLoadComponentEvent":"LITHIUM:lazyLoadComponent"},"misc":{"isLazyLoadEnabled":false}}); ;(function($) { function makeid() { var text = ""; var possible = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789"; for (var i = 0; i < 5; i++) text += possible.charAt(Math.floor(Math.random() * possible.length)); return text; } $(document).ready(function () { $('body').on({ mouseenter: function(evt) { if ($(this).parents('.lia-component-users-widget-menu').length > 0) { return; } if ($(this).hasClass("disable-hovercard")) { return; } evt.preventDefault(); evt.stopPropagation(); $('.hc-user-profile').removeClass('hc-animate-in hc-is-shown'); if ($('.hc-user-profile', this).length > 0) { $('.hc-user-profile', this).addClass('hc-animate-in hc-is-shown'); return; } var unqId = makeid(); var userId = $(this).attr('href').substring($(this).attr('href').lastIndexOf("/")+1, $(this).attr('href').length); var divContainer = $(''); $(this).append(divContainer); $(divContainer).addClass('hc-animate-in hc-is-shown'); $.ajax({ url: '/plugins/custom/cisco/meraki/profile-card?tid=4044071908055355199', type: 'post', dataType: 'html', data: {"userId": userId, "unqId": unqId}, beforeSend: function() {}, success: function(data) { $('.info-container', divContainer).append(data); }, error: function() { console.log('your error message should go here.'); $('.info-container', divContainer).append(''); }, complete: function() { $('.spinner', divContainer).remove(); } }); }, mouseleave: function() { $('.hc-user-profile').removeClass('hc-animate-in hc-is-shown'); } }, 'a.lia-link-navigation.lia-page-link.lia-user-name-link,.UserAvatar.lia-link-navigation'); }) })(LITHIUM.jQuery); LITHIUM.PartialRenderProxy({"limuirsComponentRenderedEvent":"LITHIUM:limuirsComponentRendered","relayEvent":"LITHIUM:partialRenderProxyRelay","listenerEvent":"LITHIUM:partialRenderProxy"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:partialRenderProxyRelay","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":document,"action":"partialRenderProxyRelay","feedbackSelector":false,"url":"https://community.meraki.com/t5/forums/v5/forumtopicpage.liabase.basebody.partialrenderproxy:partialrenderproxyrelay?t:ac=board-id/forum/message-id/1654","ajaxErrorEventName":"LITHIUM:ajaxError","token":"lrpOSphEt3EIAgLzEVgLUPqiR_G8e2SWLEVPyc6UxKw."}); LITHIUM.Auth.API_URL = "/t5/util/authcheckpage"; LITHIUM.Auth.LOGIN_URL_TMPL = "/plugins/common/feature/saml/doauth/post?referer=https%3A%2F%2FREPLACE_TEXT"; LITHIUM.Auth.KEEP_ALIVE_URL = "/t5/status/blankpage?keepalive"; LITHIUM.Auth.KEEP_ALIVE_TIME = 300000; LITHIUM.Auth.CHECK_SESSION_TOKEN = 'jMemhQaZHCpiptGCjW8d_Gwow-wi3j5mi1aaaRLq3CQ.'; LITHIUM.AjaxSupport.useTickets = false; LITHIUM.Loader.runJsAttached(); // -->
