Meraki GO AP losing internet connection
WDB2721
Just browsing
I have a security gateway, 24 port switch & 15 meraki GO indoor AP's.
The gateway & switch are online, I connect the 1st AP via PoE it comes online and internet access is fine, however when i connect the 2nd AP via PoE it seems to knock out the internet access for both ( i have also meshed this and used different hardware).
When i reinstate the old WIFI access points (these are not meraki go) using the Meraki Go switch & gateway all works fine and no internet connectivity issues. There is no broadcast storm as everything has different ip addresses.
Has anyone come across this at all please?
0 Replies 0
