Management options
Harshad
Management options
Can I manage my network thr cloud or Mobile app is the only management option available for remote mgmt?
5 REPLIES 5
GoJamesEMEA
Meraki Go Team
Re: Management options
Hi Harshad
Thanks for your post!
Meraki Go networks are managed solely via the Meraki Go App, available on iOS and Android. Being a cloud based App you don't need to be onsite to use and gain visibility into your network or perform any troubleshooting.
Best Regards
James
dgfcs
Hi, I have a question about your answer,
Agree, it can only be managed by the application but can you have several users with access to the application?
Several clients can be managed from the application at the same time (similar to meraki enterprise) or on the contrary it is necessary to log in and log in with another user.
Thank you
dgfcs
Nobody can help me?
GoJamesEMEA
Meraki Go Team
Hi There!
At present it is only possible for a single admin user to access Meraki Go, however multiple logins with the same login credentials is possible.
Best,
James
dgfcs
