Just curious.
Are the Meraki GO APs able to do Location Analytics like offered with the Enterprise Meraki Products? A team inside my organization is intersetd in them for a few different use cases, but I can't even create a Meraki GO account with my company E-mail because we are an Enterprise Customer. I get that it is an Umbrella organization inside Meraki, but locking me out from the ability to even create an account or use my current credentials is a little off?
Hi Newbrey3,
Meraki Go does not support location analytics. You are correct that an account can be either Meraki Enterprise, or Meraki Go, not both.
Regards
Lee
Hello Lee,
Is there any update on this?
We have received at the end of last year an email about upcoming Meraki Go features, including Location Analytics, but there's no additional information.
Best regards,
Sylvain
Hello Sylvain,
The Meraki Go Guest Insights feature has been launched and is available in the app. https://documentation.meraki.com/Go/Meraki_Go_-_Guest_Insights
Regards
Lee
Hello Lee,
Thank you for your quick answer!
However, what we're looking for is sending the location analytics data data to a remote server for further integration on our side, as can be done with the regular (non-Go) Meraki offers (documentation at https://documentation.meraki.com/MR/Monitoring_and_Reporting/Location_Analytics).
Is that possible with Meraki Go?
Best regards,
Sylvain Pascou
Hello Sylvain,
That is not possible with Meraki Go. DM me and we can talk a little more about your needs.
Regards
Lee
