Licenses for Meraki GX50
Asterdebian
we would like to buy a Meraki GX50, but I cannot find clear info about licenses, can someone please inform me about what we need to purchase besides the hardware? We will use the firewall also for VPN connections to the Customer's site...
Thank you!
1 Reply 1
Soichiro-Ono
Hello.
No separate license is required to use VPN on the GX50.
FAQs - Meraki Go : Meraki Go (meraki-go.com)
>ARE THERE LICENSING OR SUBSCRIPTION FEES FOR MERAKI GO?
Meraki Go has no licensing or subscription fees.
VPN supports 50 tunnels without license. If you use DNS Security Umbrella, you need a separate subscription license.
GX50 Data Sheet - Cisco Meraki
>Recommended for 50 clients
>DNS based security powered by Cisco Umbrella (additional subscription required)
Meraki Go Umbrella Security License - Meraki Go : Meraki Go (meraki-go.com)
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
