How to disable Broadcast suppression (Sony Nasne will not work)
Jubilee777
Hi My Sony Nasne connected to GS switch could not be found from my iPhone connected to GR10.
When I use other consumer AP's,  it works.
Nasne uses rendezvous and with my Cisco experience it usually one of the multicast group / IGMP / Broadcast suppression might cause.
My problem is that, Meraki go is not WLC nor ordinally Meraki. My Meraki-go could not disable those features.
Is anyone experience disabling those features or using Apple-TV on your Meraki-go?
0 Replies 0
