Help with Auto TX Power on RF Profiles
rayneraguilera
I'm trying to adjust the TX power on my access points so clients get connected to the closes AP when they move and do not get stuck to a single one. I adjusted the TX power using a RF Profile between 8 - 14 dBm, but after a while I still see some of my AP delivering 24 to 26 dBm.
This makes my clients connect to the same 4 APs. How can I adjust the TX power and make the APs follow my settings?
1 Reply 1
Franco244
You're able to adjust transmit via the app. Note that it will take some time for the power settings to sync down, maybe 1-2mim at most. But it's very much trial and error, unless you have proper wireless tools.
