GX50 - Trace traffic or read logs
anbohm
Any way to see traffic og take out logs? Hard to do troubleshooting without any logs.
Also tried SSH, but seems to be disabled.
5 Replies 5
Xydocq
hello @anbohm
Could you give more specific information on what you want to do?
anbohm
Want to check that traffic hits NAT rules and firewall rules. Also want to see if traffic from a specific IP is allowed or not. Normal traffic logs.
Xydocq
There is no such log or information available, at least from what I see.
The default firewall-rule is set to block all incoming traffic. You can't really edit the default settings. The only setting, that will overwrite the firewall-rules is Port Forwarding, to harden a Port Forwarding rule you can add "Allowed Public IPS", this can be a single ip-address or a range of ip-addresses. If you don't add an ip-address to the list, the port is open for everyone. When you add an address, the port still shows to be open on a port-scan but the firewall will block requests coming from a different ip-address.
The only information you can get, is for outgoing connections. You can find that under Hardware, if you select the GX- or GR-device you will see Unique devices. Selecting a device from that list will show you all its information, Usage and Application usage. This for the past 2 hours, past day, past week or past month.
anbohm
I think default to support "Show log" should be possible. Hope this will come in an update soon. Hard to do troubleshooting without any way to see logs. An easy way should be to have hit count on the Port Forwarding rule. Is it any special post where new feature request should be posted?
Xydocq
