GX50 Site to Site VPN Bridge mode
TTozer
Just browsing
I have two sites that have the same subnet and I need to bridge them using the Site to Site VPN, can this be done with two GX50's and how?
Xydocq
hello @TTozer
The network-addresses on the local networks need to be different.
You can't have the same IP-address on both sites, because devices won't know where that IP-address is located. Or better said, each device would search for the other only on LAN and never over VPN.
hope this helps
TTozer
Just browsing
As I suspected, these routers do not support a Bridged VPN.
Xydocq
Could you explain the term "Bridged VPN"?
In order to have a working site2site-VPN each site has to be unique when it comes to the ip-addresses (Site1: 192.168.1.0/24, Site2: 192.168.2.0/24 and so on....) If you use 192.168.1.0/24 on two sites, it won't work. Your local computers will think that any ip within that range is a local ip-address.
Routing between two or more sites will be done by the routers, they will know that an address on 192.168.1.0/24 is on site1 and an address on 192.168.2.0/24 is on site2. The route would look like this: "Destination: 192.168.2.0" "SubnetMask: 255.255.255.0" "NextHop: 192.168.1.1" "Interface: VPN"
So please let me know what "Bridged VPN" means, because I wasn't able to google that term successfully.
