GX20 setup Help
ScottWilliams
GX20 setup Help
Is it possible to set up a port on the GX20 so that a device can pass through the GX20 as if it were connected directly to the ISP modem?
Issue:
IDEXX can't remotely connect to their router in order to update the lab equipment software. IDEXX requests that I bypass my Router/Firewall and connect their router directly to the ISP modem. Unfortunately, the ISP modem only has 1 port.
My set up:
The ISP modem is connected directly to the GX20 WAN.
POE port goes to the WAP
Port 1 to my switch, then to work stations
Port 2 to a router provided by our lab equipment company IDEXX. Lab analysis machines are connected to the router.
1 Reply 1
Xydocq
hello @ScottWilliams
Unfortunately the GX20 does not support DMZ, so what you're asking for is not available out of the box.
But there might be a workaround.
In order to make it work, you need to know the port-number or port-range IDEXX uses to connect to the router. It would also be helpful to know the IP-address IDEXX has or uses for that type of connection.
Then you can set port forwarding rules on the GX20 and allow only IDEXX to use those ports.
cheers
