Cisco Umbrella Go
potat
Cisco Umbrella Go
Hi there,
I'm interested to understand the differences on the Cisco Umbrella Go and the features you naturally get through the portal at (what it used to be OpenDNS) do you still get access to https://dashboard.umbrella.com if you purchase your subscription to Umbrella Go?
Or literally the only configuration of Umbrella and insight is the 3 toggles on the app?
Thank you!
1 Reply 1
hidden0
Meraki Alumni (Retired)
Hello @potat,
It is as simple as providing the license key and enabling security features. There are no external dashboards to utilize.
Do submit feature requests in the app via the "Make a wish" tool so we know how to best display and utilize the security measures area of the app.
