Assign Aliases to Devices Connected to the Wireless Network
mbernard1
   I have a MX50 (firmware GX 17.10.2) and I wanted to see if there is a way to assign alias names to the devices that are listed as connected to the Meraki? The screen I'm referring to can be navigated to by going to the Home screen and then click on the "Unique Devices" under the "Devices" section.
2 REPLIES 2
Xydocq
You can do that by adding those devices manually to the Reserved IP adresses list
Soichiro-Ono
for your reference.
Meraki Go - Local Network Addressing - Cisco Meraki
>Device Reservations
Regard,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
