Documentation Digest: October 28th - November 13th
JohnIngram
Meraki Alumni (Retired)
China Region Cloud Maintenance New IP Ranges 2023 FAQ
Change: New article.
Cisco+ Secure Connect - Creating Access Policies for Private Applications and Network (Legacy)
Change: Added note that this article shows the legacy method of updating firewall policies in Umbrella Dashboard. The Cloud Firewall configuration is now part of the Secure Connect dashboard.
Cisco+ Secure Connect - Defining Private Applications
Change: Added notes to create an application as a object which can be used to control access from RAVPN and branch users / external browser-only users.
Cisco+ Secure Connect - Private Applications and Network Access Policies
Change: Major article update.
Meraki MX ThousandEyes Configuration Guide
Change: Added license tier capabilities table; added sections "ThousandEyes Enterprise Agent Routing Considerations"; updated chapter "Enabling ThousandEyes Monitoring on the MX Platform".
Meraki MX Subscription Licensing
Change: The features "ThousandEyes Agent Integration", "Internet Outages", "Web App Health", "WAN Health" and "VoIP Health" are now available with the Advantage tier.
MX85 Series Hardware Installation Guide
MX85 Datasheet
MX95/MX105 Series Hardware Installation Guide
MX95/105 Datasheet
Change: Added note, that MX85/95/105 supports PoE+ on GbE Port 4.
MX Load Balancing and Flow Preferences
SD-WAN and Traffic Shaping
Change: Added note that a flow preference can be configured to send that traffic over the non-primary WAN, if needing to access a local management page of an upstream device located over the non-primary WAN.
Trusted Traffic Exclusions
Change: Added note that configuration changes for Trusted Traffic Exclusions are organization-wide, so changes will affect all networks within your organization.
Content Filtering
Change: Updated section "Patterns for Blocking or Allow Listing Specific URLs".
IPv6 Support on MX Security & SD-WAN Platforms - WAN
Change: Added note that there is no option to disable IPv6 on MX WAN ports.
vMX Setup Guide for Microsoft Azure
Change: Added note to choose availability zone as “none”, Client VPN will be used on the vMX in order for the managed application to be given a basic SKU which will allow users to Client VPN into the vMX.
MI WAN Health
Change: Updated for new MI WAN Health features.
MS130 Datasheet
Change: Added PoE related information.
MS Layer 3 Switching and Routing
Change: Added note that MS Switches are unable to ping their own Layer 3 Interface; updated warning that t.he management IP for a switch (stack) performing L3 routing cannot have the gateway pointed to one of its own L3 interfaces.
MS and CS Firmware Features Directory
Change: Added MS130-8(P/X), MS130-12X, MS130-24(P/X), MS130-48(P/X) to MS100 series family.
Google Sign-In
Change: Added information about a new pre-splash info page.
CW9166 Installation Guide
Change: Added note that CW9166 APs use device to cloud connectivity method and will require TCP port 443 to be open on any upstream firewalls; added advise to refrain from using a proxy server for 443 sessions as it could cause potential cloud connectivity issues and break the firmware upgrade process.
Second Generation MV Cameras: Overview and Specifications
Change: Added MA-MNT-MV-21 to list of accessories.
Supported Operating Systems with Meraki SM
Change: Added Android version 14.x to list of supported versions.
Device posture tracking using certificates with Cisco ISE and Meraki Systems Manager
Change: Added section "Manually create ISE EAP-TLS Wi-Fi Profile in SM".
Restricting Access to Cameras
Change: Added section "Local Camera and Sensor Admins on Network Level".
Dashboard Alerts - Connectivity Issues
Change: Added troubleshooting steps for "Unreachable device(s)".
Alerts and Notifications
Change: Added note that the alert "Clients connect or disconnect from the LAN" is not available on MX security appliance networks that are set to track clients by IP address; added note that the alert "VLAN prefix shortage detected" is only available for MXs that can run IPv6".
Packet Capture Overview
Change: Added section "MR Tx Captures (Beta only)".
Best Practices for Meraki Firmware
Change: Updated section "Meraki Firmware Conventions".
Cisco Meraki Firmware FAQ
Change: Added FAQ "How do I know which firmware version to upgrade to?".
Managed Service Providers (MSPs)
Change: Added section "Recommended Dashboard Structures"; updated section "MSP Features and Tools".
0 Replies 0
