Documentation Digest: October 25th - December 2nd
JohnIngram
Hi Community,
Below are the most important changes to our documentation between October 25th and December 2nd:
Cisco Meraki Canada Region
Change: New Article.
Hybrid Campus LAN Design Guide (CVD)
Meraki Display Public Beta
AnyConnect on the MX Appliance
Change: Added statement about Session Timeout and non-support for cellular uplink.
vMX NAT Mode Use Cases and FAQ
Change: Added note, not to modify the subnets section at "Addressing & VLANs", as this will break vMX routing.
VPN Full-Tunnel Exclusion (Application and IP/URL Based Local Internet Breakout)
Change: Added note about flow decision for VPN exclusion, if DNS TTL expires.
Connection Monitoring for WAN Failover
Change: Added note about minimum firmware support for Enhanced WAN Failover and Failback and non-support for template bound networks.
MX Routing Behavior
Change: Added note, that MX cannot route between two Non-Meraki VPN peers.
MX67 and MX68 Datasheet
Change: Added FAQ, that LTE can be utilized in Warm Spare configuration.
IP Source Address Spoofing Protection
Change: Added statement, that the top 3 offending clients are logged on dashboard event log every 30 minutes.
Port Forwarding and NAT Rules on the MX
Change: Merged 1:1 NAT into this KB.
Upstream Firewall Rules for Cloud Connectivity
Change: Added section about firewall rules for Content Filtering using Talos with MX 17+.
Content Filtering
Change: Added note to enable Traffic Analysis for Content Filtering to function.
Audio Recording
Change: Added newer camera models.
MT Troubleshooting Guide
Change: Added Wi-Fi 5 (802.11ac Wave 2) MRs as supported gateway.
MT Frequently Asked Questions
MT12 Installation Guide - Water Detection
Change: Added note, that a leak detection cable for MT 12 is sold separately.
Storm Control for MS
Change: Added note about Storm Control visibility in UI. Also applies to template and bound Switch profiles.
MS Installation Guides
Change: Added note about the presence or absences of Stacking Cables.
MS Warm Spare (VRRP) Overview
Change: Added note that MS390 currently does not support Warm Spare.
MS Switch Access Policies (802.1X)
Change: Added note to disable "Increase Access Speed" when CWA with ISE is used.
General MS Best Practices
Change: Added note that changes made to L3 interfaces of MS Switches in Warm Spare may cause VRRP Transitions.
SES-imagotag Electronic Shelf Labels (ESL) Integration with MRs
Change: Updated the list of supported models and edited supported mode of operation - only token-based (JWT) connection.
Configuring WPA2-Enterprise with Google Auth
Change: Added note, that Google has discontinued "Access to less secure apps".
Wireless (MR) Firmware Features Directory
Change: Added Hanshow and SoluM ESL USB Gateway Support
Deploying Store Apps for iOS/macOS and Android
Change: Added sections on how to deploy websites to devices as apps.
Bypassing Server Certificate Validation for Troubleshooting
Change: Added section for Windows 10 / 11.
Chrome OS Enrollment
Change: General update with correct click paths and newer screenshots.
SM Enrollment Authentication
Change: Added note about Azure AD enrollment option.
Meraki and MAC Address Randomization
Change: Added section about Android MAC Randomization.
Installing Custom Apps on Windows and Mac Devices
Change: Added statement, that "Upload to the Meraki Cloud" is the only valid solution for installing custom apps.
Alerts and Notifications
Change: Added note that the "Clients connect or disconnect from the LAN" is not available, if Client Tracking is set to "IP address".
Meraki Device-to-Cloud Connectivity - FIPS
Change: Added new IP ranges and new certification document for MR 29.x.
Using the Organization Inventory
Change: Updated to include steps for both Co-Term and PDL.
Managing Multiple Networks with Configuration Templates
Change: Added sections on how to change single product networks / templates to combined networks / templates.
Creating a Layer 7 Firewall Rule
Change: "Blocking specific applications not listed under Layer 7 firewall rules" has been merged into this KB.
Summary Report Overview
Change: Added section about Ethernet Power Details.
Returns (RMAs), Warranties and End-of-Life Information
Change: Added note about the difference of warranty and license, as well as edited the RMA process in general.
Meraki Free Trials
Change: Added a few questions to FAQ section.
2 Replies 2
richardrestano
Hey guys,
I have a problem with the licensing of my organization, what happens is that it is giving a message as if my licensing is wrong, but when I look at the table of licenses that I have and what I am using, everything seems to be normal, I can't see where it is the problem. Has anyone ever experienced this?
Did you check on the Meraki Dashboard? What does it show?
