A friend of mine gave me some meraki minis like the one in this photo https://images.app.goo.gl/RuYJSLbpEDSycsSN8 that seem to be working and I was wondering if they can still be used
Are you serious? I found this PDF stating that devices that haven't downloaded 2014 firmware updates won't be able to connect to Meraki dashboard https://meraki.cisco.com/lib/pdf/eol/meraki_eol_mini.pdf so I was wondering if there is a way to connect to the devices directly using telnet and flash them with a more recent firmware.
Unfortunately some of the original Meraki gear like Solar and Mini went Eod-of-Support a couple years ago so probably not much you can do with them in this case without native Dashboard access, you wouldn't really be able to call into Meraki Support anymore on these. https://meraki.cisco.com/support#policies
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6a76a776a6a80f","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6a76a776a6a80f_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6a76a776a6a80f_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6a76a776a6a80f_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6a76a76fe85bd5","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
