How i can create native vlan in Particular SSID
Mohit_Dhanjal
Hi Team,
Can you confirm me, how i can create native vlan for one SSID i have created.
Like Native Vlan:- Vlan 25
Access Vlan:- 30
Regards
Mohit Dhanjal
2 Replies 2
When you have a switch trunk port.  For example : native vlan 1 , tagged: allow all
And you connect a AP at that trunk port.
Then you can select a tagged vlan in the ssid settings. Then this ssid will use that vlan.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/VLAN_Tagging_on_MR_Access_Points
I case you would have set the ssid to use the native vlan it would use vlan 1
Just remember that normally the native VLAN on a trunk port is used to manage the APs.
