When was my device registered?
KRam
Hello, I took over a network and am trying to determine how long my devices have been in service. I can get all the serials from the portal but am unable to locate when they were registered or put in service. Is this available someplace?
RaphaelL
Organization -> Inventory will display the date the Serial was claimed into your Org.
Organization -> Overview will display the creation of the network
Organization -> Change Log might display the date which the serial was added to a network.
Hope that helps.
You can find it in the change log, but there is a maximum time the logs are retained, so if it's something very old you probably won't have the information.
https://documentation.meraki.com/General_Administration/Privacy_and_Security/Cloud_Data_Retention_Po...
RaphaelL
Hope that helps.
If I'm not mistaken, this is only valid for co-termination, for per device license it is in the Change log of Inventory. 😛
KRam
Thanks for pointing me in the right direction! The best place I found was actually under Inventory, then Licenses which shows the activation date. Thanks to all for the help!
