TECHNICAL KNOWLEDGE
Mikkel26
TECHNICAL KNOWLEDGE
Hi everyone, I'm new at Meraki so I'm curios about Meraki SDKs, I know there is 2 one Python based and the other Node.js based but for Python I encountered two the "meraki_sdk" and "meraki"  which one of them I should be use?, both are updated? or someone is deprecadated?. For the DevAsc 200-901 certification which should I use?
5 Replies 5
rhbirkelund
You should use the "meraki" package.
Not the "meraki_sdk".
rhbirkelund
This is the one, you'd want to use; https://pypi.org/project/meraki/
Mikkel26
I was reading the Oficial Certificate Guide of DevAsc 200-901 and Cisco uses "meraki_sdk", do you know if that library it is deprecadated?, or in the exam both libraries will be included?
rhbirkelund
I don't know what the status of it is, but I can see that the latest published release is from 2019. So it doesn't look like it's being maintained.
The node.js SDK doesn't get much love.
The Python SDK is the most loved.
