It's a @GreenMan 's answer in this post.
https://community.meraki.com/t5/Security-SD-WAN/MX-WAN-ports-Without-NAT/m-p/128618#M32004
You absolutely can use MX WAN ports to link to your MPLS - and in many cases, you probably should.
As mentioned previously, for any Spoke VLANs that are configured to be 'VPN mode = enabled', their IP addressing will remain native across the VPN, inside the tunnels.
It's where you have VLANs that are 'VPN mode = disabled' where NAT comes in.   This might be for a Guest VLAN, for example.   Traffic from those VLANs, bound for anything other than a VLAN or route on the local MX would indeed be NATed out of the preferred WAN interface.  That doesn't mean that those clients can't access resources on the MPLS network (in fact, you may well want to take steps to ensure that they can't) - but the MPLS routing will need to account for the source IP being different.  Bear in mind too that any inbound session requests, (e.g. to a server at the spoke site), outside of any tunnels, will also be dropped, by default.  You would need to configure port forwarding, 1:1 NAT etc. to allow such communications.   https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
You may well have come across MPLS links being connected to MX LAN ports - this too is possible, but it delivers to a failover scenario - it's not SD-WAN:   https://documentation.meraki.com/MX/Deployment_Guides/MPLS_Failover_to_Meraki_Auto_VPN
