Meraki and GX20-HW PPPoE - configuration for CHAP authentication
Balrog
I have GX20 which doesn't seem to work with PPPoE. I am trying to fault-find this for a colleague. My network normally runs on Cisco ASA hardware - I have a known good PPPoE connection. I have entered the username and password but the GX20 refuses to work. The only result from Google is a comment that GX20 is great provided that you are NOT using PPPoE. The GX20 'Uplink Configuration doesn't have any option to choose between pap and chap which is where I suspect the problem lies - anybody know otherwise?
2 Replies 2
Ryan_Miles
Meraki Employee All-Star
You might try posting over in the Meraki Go Community
Balrog
Ryan - thanks have done as you suggest :>)
