searching for device serial numbers
nuo
It seems that when searching for an MDM enrolled device by serial number, there are some bridges to cross.
  •  Pick the right spot to search
  • Add the serial number column
Is there a field which will allow searching for device serial numbers globally on a network / multiple of networks?
Meraki developers if you look at these threads then perhaps having a global search option would be helpful / if there is a global search location, please let me know.
Alas you can only search within a network.  Not across networks.
BrechtSchamp
You could do it via scripting which will make it less labour intensive:
https://documenter.getpostman.com/view/897512/meraki-dashboard-api/2To9xm#17b33399-d50e-45fd-b1ac-a9...
schulte
Being able to search all serial numbers across multiple would networks would be a great addition. Pretty time consuming to hunt around -- seems like it should be easy enough to add a view that includes Device list in the View all networks option under NETWORK.
Darrell
schulte
How about this?
Systems Manager > Manage > DEP
I am able search for any serial number within the Apple Device Enrollment Program view. The devices list has Location (network) in the results. Beats searching every network one by one. I can work with this.
Darrell
