ipad passcode requirement
wapaktech
Does anyone know how to make so the ipads do not require a passcode to be set?
8 Replies 8
jared_f
@wapaktech I don't believe you can restrict allowing passcode to be created. If you are using DEP you could always remove the option to create a passcode during enrollment, but the user will be given the option in settings to always create one.
You could setup email notifications with a policy to alert you when a passcode is set.
Jared
jared_f
Then just clear the passcode from dashboard.
wapaktech
We're talking 100+ devices.
wapaktech
I don't want them to be forced to set one.  We are talking kindergarten students.
jared_f
@wapaktech The only way to read that passcode is to use that sort of policy and search on complaincy of that policy.
jared_f
Then navigate to Systems Manager > Clients > and Search on the Following
This would allow you to send the "Clear Passcode" command to devices that have a passcode!
wapaktech
I don't need to clear the passcode.  There isn't a passcode set.  I don't want the kindergartners to have push on "later" everytime the message pops up.(which is frequent)
jared_f
@wapaktech Could you please send a screen shot of what you are seeing?
