iPad text replacement - add to Meraki SM?
DanHarmon
Our users will be using iPads to connect to a domain website which requires domain credentials in the form of MYDOMAIN\username
If you're an IT person you know most users want to do a forward slash when a backslash is needed.
What I can do MANUALLY is create a text replacement by clicking
Settings >> General >> Keyboard >> Text Replacement and add the setting
Is this something I can do via the MDM dashboard somehow?
jared_f
This request would need to be submitted to Apple.
DanHarmon
That's a shame.  Meraki is my first MDM software.  I'll have to look into VMware next year to see what they can do that Meraki can't (I have no idea).  Thank you for your answer.
jared_f
@DanHarmon All MDMs pretty much have the same feature set because everything is based on Apple's framework. While I don't think you can set text replacement with a profile, could using the domain profile and uploading/scoping it to your device via Meraki help? You can find the following in Apple Configurator 2.Screen Shot 2018-02-28 at 4.50.29 PM.png
DanHarmon
I don't think this particular thing will help, but it's something to think about, thanks!
