iPad Restrictions
Greg3
iPad Restrictions
Good afternoon,
We have a set of iPads on Meraki MDM. We have set all restrictions we can, but we can't work out how to disable Guest Mode (temporary session as Apple calls it). Does anyone know where I can configure this setting please?
Many Thanks
DJDonovan
Meraki Alumni (Retired)
Hi Greg!
In order for an iPad to restrict Guest Mode / Temporary Session, it will need to be DEP enrolled with the "Shared iPad" DEP setting left *unchecked*.
If your iPads have already been enrolled via a non-DEP method, you will have to factory reset them and then re-enroll them via DEP and apply a DEP profile that disables the shared iPad setting.
The following documentation overviews how to set up and enroll devices via DEP:
https://documentation.meraki.com/SM/Device_Enrollment/Apple_Device_Enrollment_Program_(DEP)
There's a section within this doc labeled "Assigning Settings" that shows how to leave Shared iPad config disabled.
Let me know if this helps!
Greg3
Good evening,
Thank you very much for your response.
We still want shared iPad mode enabled to use in classrooms, but we don't want students having the ability to use guest mode, only to log in with their credentials.
Is there a way of disabling guest mode separately?
Thanks again
Greg
DJDonovan
Hey Greg,
It looks like at this time there's no way to do a shared iPad deployment while also disabling the Guest Mode feature separately.
-Donovan
Edit: It looks like Apple has recently introduced the ability to do this, but, we have not implemented it yet into our solution. I actively encourage you to submit a feature request for this ability via the "make a wish" box on the dashboard so that our Product team is made aware that we have a demand for this functionality.
