app install error help
Trout
I am using School.apple.com and meraki to administer 40 ipads. I have been asked to install new apps on them and I get "The app "whatever new app name" could not be installled and "This appleID can't be used to make purchases". I have obtained  the licenses from school.apple.com. All my certs appear to be up to date and communicating. Any ideas
7 REPLIES 7
I don't know the answer.
I believe you have to buy the app via the VPP platform.
Perhaps you haven't added the VPP account to your Meraki system.
https://documentation.meraki.com/SM/Apps_and_Software/Apple_Volume_Purchase_Program_(VPP)
@Trout  Apple ID's created within Apple school manager cannot be used to purchase App's. You need to purchase app's using VPP within ASM as suggested,
www.btr.net.nz
Ah yes silly me I should have included that @BlakeRichardson  I actually "bought" these apps through vpp so I have the licenses but when the device tries to install the app through Meraki is when I get these two errors
thats the thing I have VPP Installed and I have purchased the apps with VPP
vassallon
Here is how I have one of the apps I am pushing out setup:
@Trout  Can you post screenshots of the errors please.
www.btr.net.nz
