Zero Touch/Meraki not picking up tags and profile.
Chandra88
first time posting here so apologies if i'm asking something already resolved. i have the following all setup
  • Zero portal access
  • device from re seller purchased
  • Meraki profile setup for testing
Zero Portal - config
i have also set the config to the test device
phone enrolls to Meraki successfully
however on systems manager the phone does not pick up the tag, any suggestions on what to do, i would like the android device to pick up the profile and tag automatically rather than assigning manually once the phone appears on Meraki devices. i do not have this problem with Apple DEP devices.
Chandra
2 REPLIES 2
You can make sure of "auto" tags (which you can't configure), but you can not have tags that you have created applied automatically.
https://community.meraki.com/t5/Feature-Announcements/SM-Device-enrollment-type-auto-tags/ba-p/94722
T1
This is not entirely true, you can specify user created tags as "Default" ones under Systems Manager > General.
