Windows 10 application versions
DHAnderson
I am trying out Systems Manager using some test Windows 10 PCs.
The applications I want to install all have their own way of updating, so Systems Manager does not need to care about updating the them.
I setup the JumpCloud agent as an application, and have the URL to the download for a particular version.  When the JumpCloud agent updates itself, Systems Manager sees that the old version is no longer installed, and reports it as missing.
I want to automatically install an application, and let the application update itself to its latest version and not have Systems Manager complain about the app missing.  Is there a way to achieve this?
Thanks,
-Dave
Dave Anderson
DHAnderson
I am using a work around by using the recently-added tag to indicate which computer's should have the software installed on them.  Once I the installation is complete, I be remove the recently-added tag.
This process is somewhat clumsy, but it works.
Dave Anderson
1 Reply 1
DHAnderson
Dave Anderson
