What password is used for iOS backup encryption?
MSCICT
Just browsing
If Meraki is enforcing backup encryption on an iOS device, what password does it use to encrypt the backup? I can't seem to find this information anywhere!
Cheers
1 REPLY 1
WadeAlsup
Hi @MSCICT
I believe this option is enforced when backing up the device to a computer via iTunes. It will prompt you to set a password which will then be used to decrypt that backup in the future.
See Apple Support Article
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
