VPP replaced with Apple Business Manager
Dan2
So our VPP token expired and it won't let you log in to Apple to renew it. I was off sick when this happened, but apparently we've had to create an Apple Business Manager account with a new email address, and add that to Meraki.
However, we've purchased quite a few apps on the old account which we can obviously no longer assign out. My boss said Apple alluded we may be able to migrate the old licenses on to the new account. Is it best practise to do this then remove the old VPP account? Will I still be able to uninstall apps installed with the previous VPP account?
Thanks,
Dan
5 REPLIES 5
BlakeRichardson
@Dan2  you can link legacy VPP acocunts to ABM
We had the same thing seperate DEP and VPP account before Apple released ABM and ASM, we linked both accoutns and now all is well. There should be a support number you can call if you get stuck.
www.btr.net.nz
@BlakeRichardson , so I presume I just follow these steps to link the old VPP account to my new business manager account? https://support.apple.com/en-gb/HT207867
Then go to Organization > Configure> MDM in Meraki and remove the old VPP account so the old apps aren't listed twice?
Thanks,
Dan
@Dan2  Yes just follow those steps. Re setup in Meraki I don't think I had to change anything as the original VPP account is still working you just administer it through ABM now instead of the old VPP login.
www.btr.net.nz
@BlakeRichardson thanks.
Not Meraki related, but do you use Apple Configurator? I'm wondering if I'll still be able to manage my iPads I configured with it if I change the sign in to the new account
Thanks,
Dan
@Dan2
Yes you can still use configurator with ABM / ASM. I do use it for iPhones as most retailers in my country can't register iPhones in DEP for some reason so I have to do it manually.
www.btr.net.nz
