VPP Problem
TimL
Just browsing
VPP Problem
VPP has been working for years and now when I go to it in Meraki there is an error message at the top of the page saying   "Error accessing VPP account Apple VPP Program: The sToken has been revoked"
I cant seem to find anything about this.  Has anyone come across this and might know what to do to fix it.
I cant assign licenses etc now
Regards
TIm
6 Replies 6
I recall Apple updating the VPP terms and conditions a while ago. Did you try logging into the VPP portal to see what it says?
TimL
Just browsing
I can login fine to the VPP page and also in Meraki the MDM settings are also coming up as ok
jhurley03
Go to Organization>Configure>MDM. Under Apple VPP Accounts check to see if the token expired.
RoboTech
Possible expired VPP token, they need to be renewed annually.
TimL
Just browsing
I renewed it not that long ago so all is fine as far as an expired token
jared_f
@TimL If none of the above is working, log in to deploy.apple.com and go to VPP and re-download the token. Then under Organization > MDM > (Click your VPP Account) > Re-upload token to Update. Then try are force sync via the VPP panel in Meraki.
