Tags on Apps
Android914
Tags on Apps
Hello-
If I remove a tag from an a custom Enterprise app, will that uninstall the app from the device? These are supervised iOS devices.
Thanks!
MacuserJim
Sorry, I was making the assumption that would be checked. If it is not checked then it would not uninstall. It would also not install it automatically, the user would need to download it manually from the App Store or from within the "Meraki MDM" app.
MacuserJim
Yes, as long as you have it set up to install on the iPad based on that tag.
Android914
What if the "Auto Install/Uninstall" option in unchecked?
MacuserJim
Android914
Okay, that's what I thought. Thanks for the information!
