Systems Manager Trial
Joanjo
Hi everyone,
One question, I have a client wants to set up a trial from Meraki SM. In order to use it, he has to grab a new network and then it will appear the trial. The client wants to do the trial on its own network, (he is a user of Meraki already and he has all the users, vlans an so on) he doesn't want to open a new one. Is it possible to start the trail from it's own network?
Or he needs to create a new network?. If is the case, does he need to create users and so on again?
Thanks for your help
kYutobi
You can try to create the new network then combine them. That can be done in the Organization/Overview tab.
Enthusiast
kYutobi
Enthusiast
Joanjo
Thanks for the feedback
Nash
Best practice for Systems Manager is to have a separate SM network within your organization.
Joanjo
Thanks for your feedback
