System Manager for Huawei Devices
gavila08
Hi Team,
I'm trying to integrate an Android device form Huawei but due to the "recent" changes from Huawei the playstore is not available anymore, Is there a way to integrate this android from huawei device to system manager?
6 Replies 6
I imagine this would only be able to work in BYOD mode now.  You would have to sideload the app.
Hi @PhilipDAth,
Due to the new update from Huawei there is only access to the device through something called "Huawei ID" after that only exists an appGallery for Huawei. I tried to associated my google account to the device but the apps (or even the playstore) are not appearing in the device.
I also installed the gspace for all the goolge stuff but still not able to install the work profile in the device.
Hi @PhilipDAth,
As you mentioned I installed the sme.apk file and I was able to create the work profile but unable to install the apps due to the missing google playstore. HuaweiError-SME.jpeg
And the new Huawei devices has their own app gallery. Also tried to replicate the system manager app into gspace without any success result.
I see.
I can't see how that would work.
Mike_fbr
Hi! any update on this issue with huawei devices? Is there any way to use Meraki MDM on Huawei devices or are they not supported?
They wont work, as they don't support Android Enterprise.
