Stop Screenlock during active use
AWilkin
Apologies if this is obvious, but is there any way you can disable the pin lock during active use on an android device?
I was unable to find any documentation regarding this
1 Reply 1
There is no direct setting in MDM to disable screen lock during active use for Android devices, however if your devices are in Device Owner Mode, you can use Kiosk Mode to lock the device to a specific app or set of apps.
Android Kiosk Mode in Systems Manager - Cisco Meraki Documentation
