I'm not able to save documents to iPad on my managed iPads. Could there be an option somewhere that prevent doing that? I looked everywhere in the settings menu in the Systems Manager dashboard and didn't find anything.
Has there been any restrictions set on the iPad without going through Systems Manager?
@BlakeRichardsonwrote:Has there been any restrictions set on the iPad without going through Systems Manager?
No restrictions has been set without Systems Manager, all of our iPads have been configured entirely with Systems Manager.
How are you installing the documents? When saving are you speaking of the open in function? Check your restrictions for the following:
By example, if I want to save a picture from Safari, I click on the picture then the "Send to icon", then "Save to FIles". On that window, "Add" option is grayed out, if I click "On My iPad", nothing happens.
There is an app we are using at the job where we can consult documents, downloading says documents is the same as in Safari.
The two options are check :
What Kind of Restrictions do you have set up for it ?
