SM Screen lock/Require Password Security Policy (Agent 4.1.1)
DarrylP
Hoping the community can assist with SM issue during a proof of concept testing stage to troubleshoot the following.
Windows 10/11
Single SM Security policy with Desktop "Screen lock after" X minutes enabled set for 20mins
Agent ver 4.1.1 (same experience with 4.0.1 prior to upgrading)
Device is reporting as online/non-compliant with
Screen lock: Disabled
Require password after : - minutes
This is despite having enabled screen saver with 'on resume, display log-on screen and confirming password is required upon resuming.
Wondering if something has changed between OS or Agent versions where this was previously supported and no longer working?
1 Reply 1
IMHO - to be completely open - Systems Manager support for Windows is not good.  Lots of things don't work well.  It is only suitable if your use case requirements are very basic.  Also, the team don't seem to be interested in doing development on Windows to bring it up to speed.
