We are an LGFL school and been given free access and actively encouraged to install SENSO. Safari and any other browsers are removed, the SENSO app is custom pushed out to devices and students login using Microsoft credentials to browse thus allowing monitoring on the iPads, viewed on a central console.
This works perfectly when no restrictions are applied to the iPads however there are a set of suggested Restrictions on Meraki and a number of them have been applied since we first started using Meraki. Something is blocking SENSO when the restrictions are applied. As there are about 100 potentials, wondering if anyone else has encountered and knows what to avoid so that I can test what the implications might be for security on any other apps?
Have so far turned off previously engaged settings as follows:
Age range
iCloud iOS: allow managed app to store data in icloud
Managed apps cloud sync
app installation
UI app installation
UI configuration profile installation
but so far no luck. I'm going to be here a long time turning everything off and on to test! Any ideas as to what could be causing the block. The app turns up in Meraki SM but never installs if the group restrictions are applied.
