We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Hi
I trying to use the tutorial for renaming 100+ names to serial numbers of devices Renaming Systems Manager Client Devices with a .csv and Meraki API using Postman Runner - Cisco Mera...
And after doing all steps, I receive every request same error: 502 Bad Gateway
the PUT line:
{{baseUrl}}/networks/{{networkId}}/sm/device/fields?serial={{serial}}&deviceFields={"name":"{{name}}"}
the CSV file looks exactly like the template (2 columns serial and name)
Solved! Go to solution.
The solution in this article is correct - Solved: Re: Trouble Renaming Devices via Postman - The Meraki Community.
The reason why it wasn't working was in the Renaming Systems Manager Client Devices with a .csv and Meraki API using Postman Runner - Cisco Mera...
There is an error in step 4:
should be devices not device
Works in both api v0 and v1
v0 - UpdateNetworkSmDeviceFields
v1 - Modify the fields of a device
So make sure to check your path (don't be silly as me) and change the body like in solved topic.
Try with API v1 instead v0:
https://developer.cisco.com/meraki/api-latest/#!get-network-sm-devices
HiThe same issue with API v1 as with API v0, I can access the sm devices list, but I need to change names to the serial number.
I also tried the solution from this article Solved: Re: Trouble Renaming Devices via Postman - The Meraki Community
And still get the same error, what can be wrong?
I've also noticed that error 502 changes to 400 when I remove the host from headers, is there anything that I can change in this setting?
