Profile-based FileVault encryption not working on MacOS Catalina
Hannes_CD
When trying to enable FileVault by profile, when shutting down the client, we get a prompt, asking for the device credentials in order to enable FileVault, but the device just shuts down/restarts without actually encrypting the hard drive.
JAMF is facing the same issue, but their profile configuration allows either encryption on startup or shutdown. The startup option seems to work.
Please implement an option to choose if the encryption should take place on startup or shutdown to cope with one of many bugs in Apples latest OS.
3 REPLIES 3
Noah_Salzman
Meraki Alumni (Retired)
Hi Hannes_CD,
Can I trouble you to open a support ticket and then, once you have done that, post the case ID in this thread?
Thank you,
Noah Salzman
Product Manager for Meraki SM
Hi Noah,
the case ID is 04590821.
schalabi
The issue is Apple has changed the way the Filevault payload is installed on Catalina.
Under Systems Manager > Manage > Settings > (select your profile name) > Filevault
Enable the following:
CHECK Defer encryption until after reboot
CHECK Defer enabling until logout
0 Maximum number of times users can bypass
Make sure you check your device into dashboard to pull down the new profile configuration settings then give your device a power cycle.
