One Plus 10 Pro Oxygen OS Has anyone enrolled this? Can it be managed? Any issues?
ElonTesla
I know the answer will be not supported, but has anyone enrolled a One Plus 10 Pro phone running Oxygen OS?
Oxygen OS is based on Android 12.
2 REPLIES 2
BlakeRichardson
I am not sure why you would want to enrol a device that's not supported. You could always ask support if they plan in supporting it in the future.
www.btr.net.nz
ConnorL
Hey @ElonTesla,
Any device listed on Android Enterprise Solutions directory should work, there are 10 OnePlus devices but they're all running standard Android rather than Oxygen OS.
You'll likely be able to enrol the device, so long as OnePlus haven't made any major changes to the AfW framework and Google Play Services are installed. But Oxygen OS isn't a tested or verified platform, so your mileage may vary and Meraki Support will not be able to assist you should you experience issues.
Cheers, Connor.
